When doing head gasket, you have to remove the header bolts which are the ones that hold the exhaust down pipes to the heads.
Do these bolts need to be replaced? They seem a little weathered.
Also, I looked for a replacement bolt. The originals seem to be flange bolts that are M8x1.25 25mm.
Can't seem to locate them easily. The dealer probably has some, but not cheap.
Do they need to be flange bolts? Would a regular hex head with or without a washer work?
