:merc: Hi All Need a little help with my daughter's 97 Sable. Interior lamps are not comming on when a door is opened or the dimmer control is switched to turn on the dome lamp. Map lamps and glove compartment lamps work as they should. The interior lamps relay is ok. I am using the Chilton manual for this Sable but what it does not give me is the door switches prints and the location of the interior lamp relay control (a generic electronic module). I suspect that it is not passing the ground to the interior lamp relay. So I really could use a little help with this problem and it will be very much appreciated. Prints, location info, and/or any help? Going thru the prints I have found several relays are governed by control modules or possibly a control module generating grounds to the various relays, so some tutoring and help would help pop take care of his daughter's new old car. Thanks
