03, sable.
My car starts and continues at about 1700 rpm before going down to 750 rpm. it takes about 1 minute to gradually get there. It also continues to run at 30 mph once down the road even after removing foot from accelerator.
i test the iac today with volt meter got, 11.5 volts, haynes says between 10.5 and 12.5 is good.
i tried my to test TPS with meter. I could't get a good connection. Tried to stick in paper clips (one into ground the other into the signal wire) from backside of harness without any luck. I wanted to check if the the meter went from .1 to 5 volts as i increase the accelerator.
How do I get connection. Do i forget about paper clip and shave back just enough of the insulation on the ground and signal wire to check. i just don't like the idea of shaving it back. i was going to put some black rtv on the shaved bare section of the wire afterwards to prevent any future grounding of the wires
