The last person (some Ford dealer in Lexington, SC) superman'd on the oil pan drain plug. Just confirming that a 13mm socket is used on that before I start hammering away on the ratchet to loosen the plug? Thanks.
Already took the y-pipe off.No clue what size.. but make sure you do it when the engine is hot. MIght help a tad and lets the oil flow better.
I gota take the pan off, so either the oil comes out the drain plug or I'll make a large mess on the garage floor loosening all the oil pan boltsThey probably used an impact wrench to tighten it. Look out for crossed threads.
They won't fit, tranny pan in the way :\.Heh.. You can get adaptors from 3/8 to 1/2"
Torch?
Yup. Learning a lot as well...and regretting some things too.I think he's changing the pan gasket.
That and stripped or severely over tightened oil pan drains are why you can't trust an oil lube shop.Superman also installed my oil filter...hopefully i can use rubber jar openers or something and hopefully make that work.
Always oil the new oil filter gasket before installation.[/b]
