I found this little tool the other day when picking up my Calipers. It is basically a big metal hollow dice with tabs for different size calipers on fairly common size vehicles. It was $13 and some change after tax. I know of at least three vehicles it can be used on and the tab facing the camera should work for the 13 Taurus. Insert the appropriate tab on the caliper and with a 3 or 4 inch 3/8 drive socket extension bar and ratchet turn as necessary to flush the piston. This step is usually necessary when replacing brake pads as the new pads are usually higher then the ones being replaced. Front pistons can usually be pressed in by a C clamp and twisting the C clamp with the OLD pad to flush the piston.
NOTE: Removing the Master Cylinder cap will make it easier but be ready for some minor brake fluid loss....adjust clean up rag accordingly.
