First off, I must start by saying that I know little to nothing about air compressors, and don't even know if the part that I want to use is even even called an air compressor. Actually, I don't even know if the part exists.
What I want to do is store excess boost from a turbo charger. I have a 1994 Taurus sedan, 3.8L. I can't afford to reinforce or rebuild anything, but I'd like to increase my horsepower from 140hp to 200hp.
Calculations
Desired horsepower increase
200/140 = 142%
x/14.7 = 42%
x = 6.174
Required boost at 100% efficiency
6.174 PSI
Required boost at 80% efficiency
1/0.8 * 6.174 = 7.71 PSI -> 8 PSI
Because there will be a valve releasing excess air, I would like to capture it, using some combination of valves and air powered air compressors. What I'm visualising in my mind when I say "air powered air compressor" is a device which takes the movement of air through a turbine (placed after the release valve), to power a pump that moves 1/5 to 1/10 of the mass of air flowing through the turbine into a storage tank, which should allow a theoretical maximum pressure 5 times that of the excess pressure coming from the turbo. The reason for storing the excess air is to be able to provide a larger initial boost from a stop; which brings me to the next thing I would like to attempt to do: Have a switch that when on, would allow the air in the compressed air tank to make up the difference of the turbocharger's missing initial boost at wide open throttle. It is meant just as a buffer, enough to get the car going long enough to get all of the 8 PSI to come only from the turbocharger (which I think would be half of first and a bit of second gear).
Any input appreciated!!
Calculations
200/140 = 142%
x/14.7 = 42%
x = 6.174
6.174 PSI
