I have a 95' Taurus with the 3.8L and started having the airbag light start flashing codes at me. First it was code 34 then this morning I noticed it was showing me 35. I have done a search and the only cars I have found codes for is pre 92' and post 96'. It would seem that the codes were about the same so I am assuming since they were similar problems they would be probably the same for mine.
If I remember correctly the codes were Drivers side and Passenger side Squib’s are shorted. The only squib I have ever heard is a small explosive, and knowing how airbags work I am guessing that with the charges shorted there is no way to fire the airbags if I get into a wreck (somewhat likely). Besides I am sure the system is off line if the airbag light is on or flashing.
I have also noticed that the code doesn’t always show up It may do it one day and not another, or one start and not another (like going to a corner store or something).
Little history, about 2 years ago I ran into someone with a long receiver extension hitch and damaged the bumper cover at the level where the cover transitions flat on the top. This punched a hole in the cover but went no further. About a year later I ran into a pole while parking. I got about 1 ½” too close and the bumper cracked and the drivers side fell off. I replaced the bumper cover and inspected everything at that time. The sensor was not damaged and I am not thinking that this is the problem.
Where is the most likely spot that would cause both airbags to be shorted?
Thanks
Jeff
Thanks
Jeff
