Another System to Lean question on a 1998 24v DOHC Taurus. 114,000 miles on engine. DPFE, egr, plugs and upper intake gasket replaced 2 yrs. ago. I've cleaned the MAF sensor and still the same codes Po171 and 174.
The engine can sometime have a miss at idle, will decrease in rpm's down to 500 and then back to about 900 rpm. It accellerates and runs down the highway just fine with no issues. The fuel mileage has dropped also.
I've read on here where vacuum leaks may be the problem, particularly the pcv system. Is it possible to get to the pcv and its components without removing the uim on this year engine?
