Originally posted by Ict_Lx@Aug 18 2005, 05:14 PM
And I'm retarded. I have had the problem with two different keys. Logic would suggest that the system is screwed up.
No your not retarded, let me explain two instances of a PATS failure that I dealt with at the dealer.
Both cars were towed in due to a no start.
The theft light was flashing like the heartbeat of a humingbird, and other the same, when all diag was completed and the system reset on both,.... both vehicles fired up like nothing was ever wrong,...
Ok here comes me with a deer in headlights look, I fixed both and didn't know what the crap I did.
Found out by calling the Ford hotline to ask the customers if they were parking in or around high tension power lines and or some sort of electronic equipment, and the answer was yes from both customers, one worked for Alabama Power, and the other to one of the local cable stations.
Seems when ever they parked their car or drove under/around these high powered systems, there was enough RFI in the air to make the PATS go wicky wacky, for lack of better terminology, :lol2: the RFI caused both cars, systems to go blank or something, and had to be reprogrammed, and the customers were both directed to avoid those parking spots/routes thru their original path, and both had come back for regular maint, .. etc:
No more problems with the PATS getting stupid.
Ford issued a TSB or a SSM on that shortly after our experience with the odd problem, and evidently other dealers had the same type of problem, cause Ford don't issue a SSM unless IIRC at least 10 complaints hapened, or a certain # more for a TSB :dunno:.
