Duratec Headbolts Don't Work For V8 Sho
1 reading
10K views 44 replies 12 participants last post by  navalavi8or
#1 ·
SHO Headbolt on top, Duratec Headbolt on bottom:
As you can see, the Duratec headbolt is about 1/2" longer. The shaft diameters are the same, as is the thread pitch. Promising...
SHO Headbolt on left, Duratec Headbolt on right:
Same head size.
Washer size comparison:
SHO headbolt washer is slightly larger in total diameter.
Headbolts hand-tightened in head:
As you can see, the Duratec headbolt bottoms out before it makes contact with the head. The Duratec bolts are just too long.
#2 ·
I never could get a TH400 to bolt up directly to a 460 Ford Big Block either
Mike
:p
#5 ·
I don't know a whole lot about head bolts but couldn't you simple shorten the duratec head bolt by a half inch? Find a nut that will fit and get to cutting with a hacksaw. Remove the nut and it should be good to go. Isn't it that simple? :dunno:
#6 ·
the length of the shoulder is the problem. the threads don't go far enough up the bolt to take and shorten the bolt up.
humm....... have you looked into arp head studs for the tec?
spridget, is there any difference between the 2.5 and the 3.0 head bolts?
this realy sucks for the v8 guys.
#7 ·
2.5L and 3L Duratec head bolts are the same. ARP does make a set of Duratec head studs... listed for the 2.5L but obviously, they work on the 3L as well. Problem is, a set of ARP studs runs about $200 or more, and there aren't enough in a set to use on the V8. You'd need 2 sets, and have a lot of left overs.
So I take it new V8 head bolts are next to non-existent?
I wonder if a set of 4.6L V8 bolts would work.
#10 ·
the length of the shoulder is the problem. the threads don't go far enough up the bolt to take and shorten the bolt up.[/b]
You are correct. the threaded length for both bolts (SHO and Duratec) is the same - I need to thread further up the bolt. I think I'm going to stop by the parts store after work and get a die and give it a try.
#11 ·
More information (because I'm likely to forget if I don't post it):
1. The bolt is M10 x 1.5mm
2. The threads are rolled in, not cut. Therefore I can't cut them longer without altering the properties of the bolt and creating stress risers.
Looks like Duratec ARP studs are the next option to consider.
#12 ·
I was thinking about that too... I was looking at a Duratec head bolt and thinking you could not cut new threads. You'd risk having the bolt crack once it's fully loaded. The threads are rolled just like you stated.
#13 ·
It makes sense, as rolling the threads is a lot like shot-peening - it case-hardens them.
Luke, do you think you could get some Contour / Cougar Duratec guys to take some pictures and measurements of the ARP studs? I could afford to buy a set of the bolts just to experiment with as they're only $30, but a set of ARP studs is a little out of my budget right now.
#15 ·
Just shim the bolts out? [/b]
I don't know if I'd feel comfortable doing that to my engine - we're talking about a good 3/8" - 1/2" of shimming. That's a lot.
#18 ·
I could be wrong, but the Duratec bolt in that picture looks to be a TTY bolt, while the V8 SHO bolt is not a TTY bolt.
Would this make a difference? [/b]
The V8 SHO bolt is TTY as well as the Duratec bolt.
Paul, I completely forgot about our conversation at my place a couple weeks ago. I'm going to go out in a little bit and take some pictures of the botls threaded all the way in the block without the head on, and we'll see.
#20 ·
Now why should I ask some one else to get pics when I have a set sitting on my shelf? :dunno:
:p I'll get some pics for you. I have some Vulcan head bolts too... I'll compare them as well.
#23 ·
new ARP Duratec head stud
used Duratec head bolt
new Vulcan head bolt
used TTY head bolts stretch 1/8" IIRC.
I notice my used head bolt has threads higher up the shaft than yours, Daniel. What brand bolt is that? Mine is an original factory bolt.... I forget exactly which engine this came out of, but looking at my assortment of used bolts, 2.5L, early 3L, and late 3L all used the same bolts from the factory.
#25 ·
Still need to know how much (if any) thread is left when the tec bolt is used in the V8 and it is bottomed out. There may be enough thread already on the tec bolt when it is cut down to the V8 length.
Looking at the Duratec bolt in Dan's pic, it has about 2" of thread. The bolts I have all have about 3.5" of thread. Since Dan measured 3/8-1/2" of spacer needed to use his Duratec bolt, I think it's safe to say, if you have the 3.5" threaded Duratec bolts, you can cut of 1/2-3/4" and still have more than enough thread on the bolt.... still more thread than the SHO bolt.
