AC Compressor Oil
22K views 2 replies 3 participants last post by  repairman54
#1 ·
Did some searching and found that Ford spec for compressor oil is WSH-M1C231-B and MotorCraft YN-12B part number. Some people state this is just PAG 46. I know that PAG is polyalkaline glycol, but does the 46 mean viscosity? I would like to purchase and add the proper oil with R134A as a charge through my AC manifold set. Would I be OK with PAG 46 or should I go to a dealer for the Motorcraft YN-12B? The oil contained in the system (2000) Taurus has a green color. Is the color the oil, or is it dye for leak detection? System has never had refrigerant added since factory fill. Compressor is engaging, but gradually not as cool (11 years old). AC gauge readings are a little low on both the low side and high side for the ambient temperature. Also, is the proper RPM for pressure readings 1500?
Thanks,
Scott
#2 ·
Yes, PAG 46 is what you want, and is the equivalent of the Ford stuff. You are correct, 46 is the viscosity rating, in centiStokes (46 centiStokes @ 40ÂşC). If you are just recharging the system, I don't think you have to add new oil unless you see it leaking out somewhere. If there's a leak, the refrigerant will evaporate and the oil will stay behind. If you add new oil, you have to worry about not putting too much in since you will not be able to get 100% of the old stuff out.
1200-1500 rpm is fine. Just keep it stable. When testing, open the windows, turn on MAX AC, and turn the blower on all the way. Ambient temperature and system load have a much greater effect on pressures than just engine speed (hotter=more pressure). Standard pressures are usually listed for 80ÂşF ambient temp, so they should be adjusted slightly depending on the temp.
I don't know what color the fluid should be or if it has a dye in it (shine a UV light on it and find out...). I think it starts out clear and a dye is added from the factory in some cases (not sure). However, if it was amber or brown I would be worried about it being broken down.
Again, I would be inclined to leave the oil in and pump down the system, then recharge away.
#3 ·
If the system has been holding a fairly good charge and just needs a slight top off I wouldn't worry about adding oil.
If it has had several top offs due to a "diminimus" leak then I would add a oz or two. The system full oil capacity is 7 oz BTW.
Too much oil will reduce cooling output.
