1992 Ford Taurus GL (3.0 L OHV) Power Steering High Pressure line with Switch
1.4K views 5 replies 3 participants last post by  chartmaker
#1 ·
Hello all,
I am replacing the power steering lines on my 1992 Ford Taurus GL (3.0 L OHV). The crossover lines that sit on the rack blew out so I made new ones using the old fittings. I bubble flared the ends and re-installed with old fittings. Hope it doesn't leak.
I ordered a high pressure line from rockauto (API 2647272990) but once I got it, I realized it doesn't have the port to connect the switch. Do I need to connect the switch? Or do I need to order another HP line (with the port for the switch).
Thanks
Ed
#3 ·
The computers might get upset, but the power steering system probably doesn't care whether there's a sensor in the line or not. You could also probably "hot-wire" the sensor so it tells the computer it's showing pressure. (Just some thoughts worth about 2 cents...) Why not just plumb it w/o sensor and see what happens?
