Has the dealer followed all the procedures suggested in this TSB ?
SPARK KNOCK—SPARK KNOCK ON HEAVY Article No.
ACCELERATION—VEHICLES EQUIPPED WITH 3.0L 00-25-5
2-VALVE ENGINE
FORD: 2000-2001 TAURUS
1999-2000 WINDSTAR
MERCURY: 2000-2001 SABLE
This article is being republished in its entirety to a. Using NGS Flash Card (4.2 level or higher)
update the vehicles affected. and Flash Cable, select “Service Bay
Functionsâ€.
ISSUE
b. Select “Powertrain Control Moduleâ€. Some vehicles equipped with the 3.0L 2-valve
engine may exhibit a spark knock condition on c. Select “EEC-V Configureâ€.
heavy acceleration with 87 octane gasoline. Hot
weather and lower octane gasoline may contribute d. Press trigger to continue on emission
to the concern. compliance authorization screens.
e. Highlight the Octane Adjust column and ACTION
press trigger, then rotate the dial to change If the spark knock condition is still present after
the ignition timing from “No Retard†to performing normal diagnostics, check for potential
“Retardâ€. Press trigger again. lean contributors and perform Engine Octane
Adjustment. Refer to the following Service
f. Highlight Fuel Octane and press trigger,
Procedure for details.
then rotate the dial to set the octane to 87
Octane and press trigger again. SERVICE PROCEDURE
g. Press the Start button. You should receive a 1. Verify spark knock condition and follow normal
message saying that the change has been diagnostics found in the Powertrain
successful. Control/Emissions Diagnosis (PC/ED) Service
Manual. NOTE
FAILURE TO PRESS THE START BUTTON WILL 2. If spark knock condition is still present after
RESULT IN CHANGES IN OCTANE normal diagnostics, perform the following steps.
ADJUSTMENT NOT BEING ACCEPTED.
3. Check all potential lean contributors including:
h. Exit out of Service Bay Functions.
a. BARO reading (mass air flow sensor) is
OTHER APPLICABLE ARTICLES: NONE correct at 150Hz+ at sea level.
SUPERSEDES: 00-22-3
b. Verify correct fuel pressure. WARRANTY STATUS: Eligible Under The
Provisions Of Bumper To c. Check for vacuum leaks at the brake
Bumper Warranty Coverage booster, vacuum hoses/plumbing, vapor
And Emissions Warranty management valve, evaporative emission
Coverage plumbing, and intake manifold gaskets.
OPERATION DESCRIPTION TIME
002505A Perform Engine Octane 0.6 Hrs. d. Compare Long and Short Fuel Trims (LFT
Adjustment and SFT) to verify normal operation which is
DEALER CODING ±5%.
CONDITION
4. Use a New Generation Star (NGS) Tester to BASIC PART NO. CODE
perform an Engine Octane Adjustment using 12A650 42
the following procedure: OASIS CODES: 497000, 615000, 615500, 702100
Copyright © 2000 Ford Motor Company PAGE 1
