1 - 9 of 9 Posts
Either needs a new MFS or clean the one you have REALLY well... which doesn't always work lol. I know.... my 99 SE does it too.
Mine happens whenever it wants. I plan on changing it out to a G4 MFS. It'll sit higher on the column, but may end the autostart
I had that same issue on my '99. Would be a beautyfull day, not a cloud around and they wipers would cycle once for no reason at all. :huh: I agree, your MFS is bad, and just cleaning it may not work for long, time for a new one.
yeah i had the same problem replaced the multifunction switch make sure you get the 4th revised switch i never have a problem now
3rd the MFS. It includes the hazard switch when you remove it so you won't be surprised. You have to remove the cover over the steering column. Once that is off, it's one connector and a few screws if I remember correctly. I was cheap and got one from a junkyard. Been working ever since.
1 - 9 of 9 Posts
