Read up on a problem I'm having with the wipers on my 99 Taurus. It only works on high.
Saw several postings about replacing the relays in the mysterious box next to the battery. Went to the local salvage yard and pulled all 7 relays out of an old Taurus and replaced them one by one. After each replacement, I'd check the wipers again and if there was no difference, I'd put the original relay back in. After replacing all relays one by one, and seeing no difference, I replaced them all with the salvage relays. Again no difference.
Decided to go the route of the Wiper motor and began the task of removing it. Here's where it gets interesting.
As I was removing the cowl, I noticed that there was a very small hose attached to the clips that held the cowl in place. I also noticed that it was in several pieces, and clearly wasn't doing whatever it was supposed to be doing.
Can anyone tell me what this is, or what it does? It looks like a very small vacuum hose, running from one side of the engine compartment to the other. It attaches to a small square device on the driver's side that looks like something to do with the A/C. On the other side it attaches to a round component on the top of the passenger side firewall.
Anyone? I was going to take pictures, but the daughter has the camera.
