The windshield washer fluid hose on both my '98 and '02 cracked where it flexed from opening the hood. Symptoms were reduced flow until only a dribble was coming out of the nozzles. I originally looked at replacing it but soon realized that would be a lot of work as the hood blanket would need to come off and the other end of the hose goes into the fender well and to the washer pump. I then thought that perhaps I could splice in a new section of hose and tried to find a hose with the same diameter and some of those plastic hose connectors (barbs?) When I was unsuccessful at that I had an idea and asked the parts counter guy if he had any hose that fit over the washer hose. Turns out a 7/32" ID hose is exactly the right size to slide on over the old hose. I got appoximately one foot (at a cost of 65 cents) of hose, cut out the rotted area of the original hose (I needed to pull the hood blanket down a bit to get to solid hose on the hood side), put a little lubricant on the ends of the new hose (read "spit") and slid the new hose over the old hose about 1 inch on each end. The 7/32" hose fit nice and tight over the original hose, the washer now works great (instead of pumping fluid all over the engine compartment), doesn't leak at all and best of all it cost less than a buck to repair.
