I have a 1998 Ford Taurus. About a month ago I went to get into the car using my FOB but it didn't work. It would open my trunk and the red alert button worked but the lock/unlock buttons wouldn't work. I attempted to use the key and it wouldn't turn in the lock. I also tried the keypad and using the correct code didn't work either. I had to end up using a long, thin, iron tool that was slid into the car through the top of the driver's side door and hooked the door handle to open it. Once inside I started the car w/o any problems except that the windows would not go down and the locks wouldn't work. Any idea what may be causing this to happen? I haven't been able to lock my car for a month because I know that I won't be able to get back in it to drive it.
check the fuses. owners manual has a diagram of the fuse locations and numbers. spray some lube into the lock and let it sit for a little while. then try the key and turn back and forth lightly to see if it has freed up. if not spray again and repeat.
the key didnt even work?? not even the passenger side? maybe the actuators for the lock mechanism locked up somehow.
