Hey Guys,
I have a problem with my windows, The driver control can roll down and up all windows , but the Pass front , and both rear will not work with the indavidual controls. Im thinking its the lock out switch on the driver door. My question is can i bypass this switch so that the other door switches will work.
Door panel has to come off anyway, might as well replace the switch while you're back there.
Yeah, you can bypass. I'd have to look at the diagram to know for sure but you should be able to take two of the wires from the plug for that switch assembly and just cut them off and solder them together.
-FOX-
