1 - 2 of 2 Posts
OK, so after several threads I am extremely close to my final decision.
I have looked at Yokohamas, but they had them only in 215/60-16, I wanted wider.
So I found:
BFGoodrich's Traction T/A 235/55-16 tires on ASA JS1 Silver w/Machined Lip 16x7 rims
with offset at +42mm.
Do you think these babies will rub? Do you think there might be issues with saggy Taurus a** and tires rubbing in the back, since I do have sometimes 4 6'7" guys riding with me?
You may need a 3/16" (4.75mm) spacer to prevent rubbing with a 235mm wide tire at 42mm offset. Closer to 35mm offset is better for that size tire, the spacer would basically give the wheel 37.25mm offset. However, it may work without it, but I am not sure.
1 - 2 of 2 Posts
