From the sounds you're describing, it sounds like there was a valve issue, although I'm not too knowledgable on trannys, and therefore wouldn't be able to pintpoint which one...
JR
JR
There is no way the sound could have been decribed as any vacum leak.Heh. It sounded like what could only be decribed as a water fall. lol. I am going balls out with this tranny that I just got. I got amsoil fluid a cooler and some BG additive I got from my ford dealer. This tranny I am getting now only has 36k on it so I am not too worried about flushing it then filling it with Amsoil universal synthetic atf. I really want to make this one last.Originally posted by JasonBVHS@May 17 2004, 08:07 PM
I had the exact same issue right after i had my tranny rebuilt. for me it was a vacum line that wasn't attached all the way. but you might want to check your PCV valve for any leaks. it would explain why your hearing the noise when just cruising, and not at WOT. The EGR plates close at idle and at WOT.
