· Registered
I have a 2010 taurus. When I push down on the throttle, gas smelling white smoke comes from the exhaust and after a few seconds the rpms start to jump between 50 and 150.
There's no crack or leaking gasket that I can see and my dad says it might be the injectors.
Any ideas??
· Registered
Sounds like a vert typical water pump failure. You can look on the forum as there are tons of information about the issue. Get ready for an expensive repair. I would hope you might have an extended warranty. It is just $1400 to replace the water pump not including any damage it has done.
TBB
