There's been a lot of posts on start up issues. Obviously a bad starter makes a whirr but often also cranks so you get a whirr but the car still starts. A complete starter failure is not far away. A low battery- a lower audible whirr but it is easy to check for a bad battery. The starter and alternator have been checked- both okay on test. . This once a month thing has been going on for a year. I can't figure it out. The linkage seems tight, the switches okay. I've been told a bad tooth on the flex plate will make a sound while the car is running and the flex plate usually stops in one of three positions so a problem will occur a lot more than once a month. Yyet another guy says high power lines can cause a problem.
2002 Taurus Wagon 3.0.
Well yesterday a mechanic said there is a chip in the key that if bad, the engine doesn't recognize so it whirrs but no crank. I held up the larger devise to which the kay is attached, (not sure of the name) in which you hit to lock or unlock doors and the guy said no, it is the key its self- hidden inside the plastic. I have never heard of this. Strange thing is, I have recently been wondering if it was something connected to the computer.
Any comments appreciated.
