1 - 2 of 2 Posts
I know about the pinch bolt and the stabilizer link. My question is there is what I believe is called a trailing arm and then there are two other arms attached to the spindle. These two arms are like a swing arm and go from the spindle to the center of the rear of the car. Which do I remove in order to lower the rear knuckle? If it is the trailing arm, how does it separate from the knuckle? Thanks.
QUOTE (clydesdale @ May 30 2010, 06:42 PM) index.php?act=findpost&pid=807968
I know about the pinch bolt and the stabilizer link. My question is there is what I believe is called a trailing arm and then there are two other arms attached to the spindle. These two arms are like a swing arm and go from the spindle to the center of the rear of the car. Which do I remove in order to lower the rear knuckle? If it is the trailing arm, how does it separate from the knuckle? Thanks.[/b]
Loosen the training arm nut, remove the swing arm nuts/bolts.
1 - 2 of 2 Posts
