1 - 12 of 12 Posts
· Registered
I have a 2000 taurus, and I need some input on where I should mount my amp. I have a sundown saz 1500d. My box will take up most of the space past the wheel wells, and I would like the amp to still be accessible. Now I need to keep the front portion of my trunk(by license plate) open for samples that I travel with, so I cannot just through it down in front. Would love to see some pics of what you guys have done.
Thanks
· Registered
ive seen a lot of them mounted on the wheel wells on some 3/4 mdf.
i dont have any pics of mine anymore but i mounted mine on the larger one of the fold down seats on the passenger side looked really nice due to i had the wires and everything under the carpeting.
· Registered
This is something that I need to do with my car. Does anyone have any instructions on how to mount the amp on wheel well? I am thinking right now of this.. remove the black plastic wheel gaurd, drill four holes in the well side drill matching holes in a piece of MDF or wood. Buy succiently long bolts or nuts from Lowes and attach the board to the well. Screw the amp on the road. Did I miss anything?
· Registered
My amp is 21 inches long, so if there is any hope to have it mounted on the back of the foldable seats, it's behind the larger one. But them, I won't be able to transport cargo that needs that space. I have transported a lot of disassembled furniture protruding through that seat. So I am gonna have to figure out how to mount a board on a wheel well, left side.
· Registered
that's some power!!! og??
where did you run that through?? under the car to the trunk??
I had to remove the fuse box under the dash i get a hole big enough to put the wire through then the wire just runs right long side the driver seat under the carpet then under the back seat. everythign else is ran the opposite side to reduce the signal interferance. Lot of work to man handle that wire as well doesnt bend to easily...
· Registered
i mounted my amp on the back of the rear seat. it works fine, doesn't over heat and its easy access
1 - 12 of 12 Posts
