There's gotta be a bolt holding the batter tray to the body. Where is it? How many? View is completely blocked by ABS module/pump. Thanks.
EDIT: I mean the battery tray bracket. The L shaped metal bracket underneath the plastic tray.
2005 Vulcan
^+1 I never could find that f***er! Would have been a lot easier to service my smog pump when it needed it. I hope somebody chimes in.
1997 Ford Taurus 3.0L Wagon 226,362 miles
Sounds different on yours (I don't have ABS), but on my '97 there are two 10mm bolts (and a locating stud) holding the L-shaped bracket to the sidewall underneath the battery tray.
Even on my car (with no real obstruction), you can see and feel the lower bolt, but then the 2nd one is high up (diagonally) tucked right at the 90-degree bend.
Knowing the location and the number will help me locate them. Thanks a lot.
