As title says. 01 ses vulc.
It is white with a pink stripe. Image below. I found it while trying to locate a bank 1 seosor 1 problem. Looks like PO slide some wire shething over it.
Not sure but it looks to be a ground. You can check with an ohm meter from it to the engine block and if the meter pegs then it should be a ground if you get resistance reading it may not be. I'm sure someone w/more knowledge will reply soon. I'm still a virgin with the recent purchase of the 99 in my signature - haven't even picked up a shop manual for it yet. Keep us posted.
In the Haynes manual, the wiring diagram for the starting and charging system shows a WHT/PNK wire running from the 'Starter Motor/Solenoid' to the 'Transmission Range Sensor'.
