I just did the install and it is easy. Now it does require removing the whole headlight, but thats not as hard as it seems. There are 4 bolts holding it on. You should be able to point them out, but the forth one is a long bolt that is silver at the top. I wish I had pics it would be easier to explain but this is a basic guide.
-Loosen them all and take out the 3 but not the forth.
-Once the headlight is lose move it out until thats as far as it goes.
-Dont pull on the headlight as you will rip the wiring.
-You will see a black circle thing where the wiring leads into.
-Unscrew that, and move it out of the way as much as possible.
-Then unclip/disconnect the wire to the bulb.
-Take out the headlight out
-Then take the bulb out, by pulling straight out, dont turn.
Reverse for installation.
Sorry for no pics, I did the install just the other night, and man what a difference!
No yellowish look pure whit, and much cleaner lighting!
Nick Saturday
