1 - 12 of 12 Posts
Taking out the battery, this just broke. It had been seeping evidently, so it was already cracked.
How do I fix this and what do I need?
thats a molded hose. really the only way to correctly fix the issue is to replace it with a new one or a one out of a junk yard.
Those are expensive as hell at the dealer. I had trouble finding it in the yard intact.
I'd almost suggest tapping the hole and using a brass hose fitting.
This appears to be the right part. It all lines up fairly close. It was about $35.00
There's no easy way to drain the radiator, is there?
Nice. I couldn't find any aftermarket stuff when I was hunting for mine. $35 isn't bad.
Discussion Starter · #10 ·
There's a handy little drain screw on the driver's side underneath the rad.
Really??? Yay!
When I changed the a/c compressor - I had to remove the thermostat housing, and of course - coolant went everywhere.
That helps take the sting out. It's not going to be *that bad* I don't think. It just came at a bad time.
Again, great knowledge from this board.
White plastic petcock on lower drivers corner of the radiator (19mm or 3/4" socket or wrench). Be sure to just hand-tighten when done or it will break off and youll be using a 3/8" allen wrench thereafter or replacing the petcock. It just pulls out and shoves back in. Another drain method is to loosen lower rad. hose on the pass. side.
Discussion Starter · #12 ·
The factory "dot" is on the white plug and radiator. So - I loosened it with a wrench, drained it and tightened back where the "dots" lined back up.
I'm having a hell of a hard time with these clamps. One of them broke. I guess I just need to cut the hose. :-( Looks like I'm going to have to take the filter box off up to the throttle body.
1 - 12 of 12 Posts
