what is the sensor called that tells transmission the brakes are pressed? where is it and how hard is it to change. i cant seem to find it at advanced auto or aurozone yet
There is no such sensor that would talk directly to the transmission. Transmission is controlled by the same PCM that controlls the engine.
The switch you are looking for is mounted where the brake pedal connects to the link for the master cylinder. It also activates the brake lights.
i think we need to know why you are asking this. the taurus is a strange beast and acts different then other cars do. so what problem are you having?
what ever allows you to shift the transmission when you press the brakes is going out. i tried to look for it on advance or autozone website real quick before i went to work but i do not know the damn sensors name or even where it is located. i am aware it was most likely on the pedal. i did not know if it sent a signal to the transmission or not but i knew it was not allowing my wife to shift her car into gear. so i assumed it was possible it did.
1 wire for the harness was broken found it after changing the switch so since it was only 9$ i left it on. and fixed harness problem solved
  • Like
Reactions: pawpaw
OK, good find, fix & feedback on your brake pedal shift/lock wiring problem.
