1 - 18 of 18 Posts
Got a question. My 2000 Taurus wagon was clunking in the front suspension when I drove over bumps. I removed the stabalizer links and the clunking went away. I drove the car for about a week before going to Autozone and replacing them. I put new ones on and the car is clunking again after a week of driving. My wife drives the car to and from work (15 miles round trip at 35mph). Will i hurt anything if I just take the stabalizer links off and keep them off. Let me know your input. Thanks.
You would effectively have no swaybar. Makes for ****** handling.
There isn't too much handling going on at 35mph. I noticed that the eyelet where the link bolts to the strut bracket would still need a bolt and a nut attached. Im more worried about the stabalizer link having an affect on alignment, tire wear, etc.
They deleted the rear sway bars in the 04 model year! :(
QUOTE (rock @ Apr 28 2009, 06:58 PM) index.php?act=findpost&pid=721444
There isn't too much handling going on at 35mph.[/b]
You'd be surprised. I watched a GN that was drag-prepped (ie, no sway bars) driving around a corner once, and at less than 20MPH, that thing was leaning worse than Chris Tucker and Ice Cube in Friday.
[attachment=29322:882833_h...width560.jpg]
QUOTE (silvapain @ Apr 28 2009, 09:29 PM) index.php?act=findpost&pid=721463
:rofl2:
QUOTE (Skinnyguy59 @ Apr 28 2009, 09:32 PM) index.php?act=findpost&pid=721464
:rofl2:
:bowrofl:
QUOTE (rock @ Apr 28 2009, 06:51 PM) index.php?act=findpost&pid=721441
I put new ones on and the car is clunking again after a week of driving.[/b]
ONE WEEK? Good Lord, what kind were they? Did they have grease zerks? I just got some new ones from NAPA 3 days ago, I hope they last more than another 4 days!!! I did notice they didn't have any grease in them out of the box, but they came with grease zerks to fill them up:
Might check and make sure you don't have a broken spring. Something like that could put extra stress on the sway bar links.
Check your swaybar bushings.
Did you get the new Duralast metal ones, where the left side is greaseable and the right side isn't? They are JUNK. I got less than 5,000 miles out of a set before they started clunking, and that was 90% highway miles. The greasable one was obviously falling apart by then, and leaks grease from the cap behind the ball joint. :(
Discussion Starter #15
I got the stabalizer links from Autozone for $19.99 each. Neither one has any grease fittings or inserts for grease fittings. I guess I should get under the car and check the busings and springs. Are there any adjustments for the struts ? Don't laugh at me.............I'm a Chevy guy with 7 G-Body Malibu's. I can build those things from the ground up. I drag race 3 of them. Anyway, I love the Taurus wagon, but lack the knowledge of how they function. Outside of visually looking at the strut and spring, I wouldn't know whats good or bad. Not to mention how incredibly dumb the stabalizer link assembly goes on. They could have came up with a better (more user friendly) design. I couldnt get the drivers side link on with normal hand tools. For the entire job, I had to use a combination of different wrenches, sockets, vice grips, hammer, and then an impact because I couldnt get to the drivers side upper nut. Crazy...............
I would definitely check the springs and swaybar bushings. The springs, because they are prone to failure depending on your location, and the bushings, because without they could be a source of the noise if they are on the way out.
Discussion Starter #17
OK. So I finally get a chance to look under the car and I find the problem. The lower nut on the passenger side stabalizer link was not tight any more. The nut "Backed" itself back about a half an inch. This was causing the clunking noise. I thought when I put them on I should have used a lock washer. The ones that came off had lock washers but the new ones from Autozone only had a nut with pinched notches to prevent the nut from backing off. The nut also had anti-reverse teeth on the face of the flat surface that was suppose to prevent this from happening. I took the nut off and put a lock washer on with it. The other nuts were tight on the rest. Lets see how long this last before I have to go back and put lock washers on all of them.
Addressing the original question - I'd be very reluctant to simply disconnect the front sway bar. As noted, it has no impact on alignment, but will make handling / body roll sloppy.
But worse, it greatly increases the chances that the car will exhibit terminal oversteer - ie a swerve in rain etc could result in a snap spin. By softening the front roll resistance, the roll resistance is effectively shifted to the back, meaning the rear is more likely to break loose first. Not a happy thing for most wives! :eek:
Maybe a defective locknut to have backed off so far so quickly?
1 - 18 of 18 Posts
