Originally posted by Haste+Jun 28 2004, 10:07 AM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Haste @ Jun 28 2004, 10:07 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-MaltaTaurus69@Jun 28 2004, 01:06 AM
A 1994 Taurus Gl with the 3.0 is definitely the Vulcan OHV 3.0L V6 Engine. 140 HP engine, the most reliable of the Taurus engines. However, your transmission is a different story. If you are already looking at a rebuild, after the rebuild, definitely look into having another transmission cooler installed. Definitely helps siginificantly with the tranny problem. Right now worry about maintenance issues to restore lost power before you start adding more. Change the plugs, wires, cap, rotor, air filter (K&N Filters are awesome) and I would also suggest the Chevron Techron Fuel Injector cleaner. It does a good job" STYLE="text-decoration: none; border-bottom: medium solid green;" HREF="http://search.targetwords.com/u.search?x=5977|1||||job|AA1VDw">job</A> cleaning the injectors, restoring any lost power. Oil change and filter change. I'm trying to cover as many bases as I can, anyone want to add to this??
BTW, Welcome to your new home, the TCCA! :banana:
:tcca:
Addiction Comes Standard
Thanks alot, I will need some more money saved up before I can get everything cleaned, fixed, altered, replaced...etc...does anyone have a estimate the cost of replacing..etc.. all of this stuff so I know what I am working with? and I am getting pics of it today to give you a better prespective.
The only thing is, after I get this done, what can I do to make the max speed faster, it's stock so it only goes up to 85 mph...damn
lol [/b][/quote]
Your car can most probably go past 85 :uptosumpn: Unless there are problems with the tranny. Your speedometer only reads to 85, but that can be easily changed with a Gen 2 SHO Speedo, direct swap. Your speed limiter should be at approx. 105 MPH, but that can be changed with a chip.
Price for a tranny rebuild is generally 1000-1500 (someone correct me if I'm wrong). Wires, Cap, Rotor, Plugs, and Air Filter can all be done in a grand total of about maybe 1 - 1 1/2 Hours. Plugs, I think the general consensus is Motorcraft Platinum plugs. I would recommend the Accel Performance Cap and Rotor set, and a K&N Air Filter. Generaly wires can run you a varied amount of prices. Mine were $75 for Magnacore 8.8mm Wires. The Accel Cap and Rotor Set you can get on Ebay for $25-$35. The K&N Air Filter will cost around $40 Brand New, but youll never have to get another air filter, just clean it every once in a while. The Fuel Injector cleaner, you can buy for about $4, you run the car to near empty, and then put the entire bottle in when you fill up, and it will do the cleaning as you drive.
