1 - 10 of 10 Posts
2006 Vulcan, gas
(hastily coppied from a Twitter convo)
Hope it's not related, but I pulled my fuel injectors to clean them, spilled a little bit of gas, and I thought "whatss the easiest way to lean this up....light it!" I took a lighter to it, it burned pretty good for a few seconds, then it went BANG. And it smoked for a few minuets. Including some from the valves (i had the cover off)
Now, the engine belows smoke, and it left a good size oil puddle as soon as I parked her.
So, what the neck did I do? And how do I fix her?
I'm not sure I understand completely what happened. Did you ignite spilled gas on top of the engine?
Hacked her up and took a look at her, that seems to be exactly what happened. Hopefully that's all.
That is the gasket that is the least restrained. But another gasket in the oil system may have been damaged but unlikely in my opinion.
OP, consider yourself lucky you didnt end up in the ICU burn unit of your local hospital.
1 - 10 of 10 Posts
