Wheel nut torque is 100 ft/lbs.
Caliper slide pin bolts is 25 ft/lbs.
Not sure exact spec on caliper anchor bracket bolts (i usually just zip em in with my impact gun) as i can't seem to access the service manuals online at the moment, but 60-75 ft/lbs would be sufficient. If you have threadlocker, put a bit of that on those anchor bracket bolts too, since they usually do that at the factory.
