1 - 2 of 2 Posts
I'm welding on some new pipe and a support bracket for a new muffler, and when doing this i know your supposed dissconnect the battery (-) and (+) post's and the (+) post on the alternator, but what i want to know, is i have like extra strobe lights, neon tubes, that are all grounded the the body of the car, if i dissconnected the (+) wire for each of these, and not the (-) wire will that mess them up, or should i dissconect the ground as well to prevent damage to the accessories (cd player, amp, neon and strobe lights)
As long as the positive cables are wired to the battery, and the negative cables are grounded to the car, if you disconnect all the positive cables, you won't have to worry about anything. If one end of the circuit is broken, you'll be fine. Just to be safe, disconnect both the positive and negative battery cables.
JR
1 - 2 of 2 Posts
