I have a weird issue with the driver door on my 2013 SEL. When I unlock the door with the key fob, I can see the door unlock clearly. I grab the driver side (only door with this issue as far as I know) and pull on the handle. Most of the time, the door will not open. I have to let the handle return to its normal position then pull it again for the door to open.
At first, I assumed I was just not fully pulling the door handle. Then I noticed it more and more frequently happening. It has no rhyme or reason to when it happens but it is probably 80% of the time or more. I know 100% the door is unlocking, but it is like the handle does not open the door for whatever reason.
Anybody experience this?
2017 Ford Taurus
Try the other doors to see if that is also there, or is it just the drivers door?
None of the others doors do it. Only the driver.
It is also the door that gets the most usage, probably 10 times more than any other door.
