Well people now i see why the guy sold the car so cheap, Here is what i have to look forward to this weekend.
1. Replace valve cover gaskets (Major Leak )
2. Tune Up
3. Transmission filter flush/fill and gasket change
4. Clean intake manifold housing
5. Replace IAS
6. Oil change
7. O2 Sensor
8. PCV valve
9. Clean Butterfly
So i have a full weekend ahead of me , anyone know the steps to replace the valve cover gaskets ?
Hardest part is removing the upper intake to get the rear cover off, and none of it is really that difficult. Make sure you get a new gasket for the EGR valve at the intake, as you'll have to either undo the EGR tube, or remove the valve. Personally, i usually find it easier to unbolt the valve rather than remove the tube, as it requires a large wrench, and is often pretty rusted in.
