1 - 9 of 9 Posts
I'm sorry if this was asked before, I tried to search for it but didn't find anything. My right headlight has water in it. It started off as a little condensation, but now it's getting worse, there's even a little bit of water pooling in the bottom :blink: . Any idea's as to how to repair/prevent this?
Repair would be to pull the headlight off and dump out the water. Prevention??? The only thing I could think of to rpevent this would be to pull the lense off the actual housing and reseal it with some aquarium sealant...
JR
Hmmm I've never seen one not start leaking after being repaired. Usually its just easier to replace the headlight only once with a new one. How does that aquarium sealant work? Maybe it might be a viable option, have you done it yourself?
The headlights on my old Topaz used to fill up with water occasionally, so to fix it, I pried off the lenses, which is really tricky, because you can't crack them in any way. Then you take aquarium sealant, which is nothing more than silicon caulk thats formulated to hold up in all weather conditions, and put a small bead around the headlight housing. You then fit the lense back over top of it, making sure you don't get sealant everywhere, and making sure that the lense is completely sealed and flush against the lip of the housing.
JR
I'm pretty sure i found the leak and sealed it, i'll check it out in a few days to see if its better. I might just go to a junk yard and grab a couple of replacement headlights, we'll see.
Drive with the headlights on for a while (or all the time) provided you don't already. The heat from the globe will evaporate the water and it will exit out the snorkel thing (provided it isn't broken).
That worked for me, and since it doesn't rain in Melbourne very often, I haven't had trouble since.
Julian
1 - 9 of 9 Posts
