Howdy,
My 1995 Sable LTS has major engine probs and the transmission is weird, too.
I plan to replace the engine/transmission/subframe assy with the guts from my totalled Taurus, and I am in need of some advice as to what I ought to do to prepare the Taurus guts for long, reliable service in the Sable.
Info on Taurus guts:
1994 3.8/AX4S, 125K mi, subframe and all guts sitting on a skid B)
Issues included rod knock on startup (going away after a minute), fuel pump shutoff after sustained hot-weather driving, trans fluid leakage from broken fitting.
Other than that, the car worked well and performed well. I do not think that the engine or transmission have any real issues.
I need advice on good things to do to the engine and ATX to prepare for a few years (at least 60K) of trouble-free service in the Sable. Any thoughts?
So far I am considering the following:
1. Replace oil pump
2. Replace all top-end gaskets
3. Check crankshaft and replace rod bearings
4. Trans upkeep, i.e. solenoids and valve body (necessary? any items to replace internally?)
5. Replace all suspension bushings including strut bearings
I am open to comments and/or criticism! :hmm:
1. Replace oil pump
