1 - 11 of 11 Posts
yeah, last night while driving to philly, i noticed high whining noise before tranny was shifting. whinning was also present while accelerating. Man, Ford must really love me to give me their one and only Supercharged Vulcan. Wow, boy don't i feel great. Seriously what the heck is the matter now?
2000+ dollars in repairs on a 50 dollar car and counting.......
sorry to go off like that dudes....just having a bad day!
ftv
That was the sound of your bank account draining.
seriously, do you mean the vulcan is about to give out?
Nah... the Vulcan is strong. My first thought would be ATX, but that's not a pleasant thing to think about. Sometimes little things like that just go away and never return. Could be anything, though. Did you by any chance top off the coolant or washer fluid any time recently? Once, I left the cap off the coolant reservoir and it ended up making some funky noises as it rubbed against the serpentine belt.
Your best bet would be to check all fluids (oil, coolant, ATF, PS, etc.) and look for anything that might be rubbing on the belts or other moving parts. I even had a tree branch stuck to the splash guard under the radiator once that had me convinced I had FUBARed my car somehow.
Are you losing any power or is the engine idling rough or anything? Could even be a vacuum leak.
i just dumped too much oil in recently...but that is all i can think off. oh i did put a lot of fuel cleaning stuff in it
ohoh....maybe something to do with that?
*shrug*
Yeah there is a high pitched whistling noise....like WHISTLING (that is the word
so it might be that then...so i definitely will check where the vacuum leak is. By the way where is this vacuum assembly kit?
Oh, no power lose detected. power is good.
Originally posted by DeltarMN@Jan 14 2004, 02:48 PM
Is it A REALY high pitched whisling noise? that lasts for about 1-2 seconds at a time? My car does this everynow and then. Never been able to figure out what it is... But there is no power loss.
Probably your alternator,a bearing inside of it or something.
Say you are parked, does it wine more if you turn the wheel a lil bit? You could have air in your PS lines, or the PS resovior is low.
Discussion Starter · #9 ·
Yes, it is really high pitched. Several passengers complained that it is annoying them. so it is very high pitched. I got used to it. One of friends told me it was the vacuum lines of intake leak.
Discussion Starter · #10 ·
actually no it doesn't make the whinning noise when i park and turn steering wheel.
it makes the whining noise when i accelerate and while shifting gears from 1 to 2nd gear.
This is an Automatic vehicle.
PS fluid level is fine and the fluid seems to be ok at the moment.
My Explorer actually had a whistling sound that was very loud...turned out to be the weather stripping had dried out because of the very cold weather. Crack the window slightly and problem solved.
1 - 11 of 11 Posts
