Hello everyone I am looking to buy a set of 18inch Volvo rims for my 2003 Ford Taurus station wagon. What size tires will fit best for my car? Thanks
Hi all, I seen online that ford Taurus rims have the same bolt pattern as my 940. So my daughter has an 02 Taurus, so I checked out the fit with her alloy spare rim. I happened to try it out on my rear axle first. After the registering pin was removed, the rim almost slipped on. I had to remove the inner hub locating lip, but then it bolted on. I think the difference is like 1.5 mm or so, and the grinding was no big deal. Just trial and error till it fit.
Tutuapp 9apps Showbox
I should’ve had a question but I think I presumed some thing. The 18 inch Volvo rims that I’ve seen were all 8 or 9 inch wide rims. My tire recommendation was for rims that would be at least that wide. If for any reason these were 7 inch wide rims I wouldn’t go above 225; 235 only with the OK of a reputable installer.
