1 - 9 of 9 Posts
So a year ago i had installed a $200 viper 2-way remote start/car alarm installed in my bull. last night a part of it went bad, the part that gives power to the heater. I called directed electronics which is the company that makes the alarm. They told me that in order to get a part i have to go through an authorized dealer. Unfortunately, any of the authorized dealers within a 200 mile range of me cannot get parts for this alarm. Best buy, the company i had install the alarm wont help me because i connected the trunk release function after i left the store (something they wanted to charge me 80 dollars to do). Since i messed with their wiring, i voided their warranty and they refuse to help me. So to make a long story short viper refuses to help me because im not a dealer, and the dealer refuses to help me because i helped myself. So now i have to butcher the wiring harness and reroute the power to the heater so that while the engine is warming, the cabin can warm too.
What model alarm do you have?
I have the model 771XV 2-way pager remote starter. I payed $383 for the thing. It appears that best buy might actually decide to help me. I got a message from somebody there after half a day on the phone and a whole day waiting. Unfortunately I didn't get the message till after business hours so ill have to wait till Monday to call them back to figure out whats gonna happen. So now i have even more wait time. The people in the Best Buy service department might actually redeem themselves, while Directed Electronics ( the maker of Viper and Clifford alarms) is still number one on my shite list for the way they were of negative help.
If you cant get best buy to help, you could connect the orange wire on the 4 wire aux output harness to a relay to switch it on and off, esentially bypassing the internal accessory relay.
[attachmentid=27778]
Yes i know that i can replace the relay. what i was trying to do was get a replacement from them because the relay in the switch box is quite small and i didnt want to add a normal sized relay in the mix (it would cause it to look very much "non-stock"). If push comes to shove ill take one of my many spare relays and, with a bit of wire, solder it right to the board. How did you manage to find the exact color of the wire i was working with so fast?
<div class='quotemain'>
Yes i know that i can replace the relay. what i was trying to do was get a replacement from them because the relay in the switch box is quite small and i didnt want to add a normal sized relay in the mix (it would cause it to look very much "non-stock"). If push comes to shove ill take one of my many spare relays and, with a bit of wire, solder it right to the board. How did you manage to find the exact color of the wire i was working with so fast? [/b][/quote]
The install manual online, coupled with the fact that the viper 5701 I am installing has much the same wire colors. You could just pull the part number off the relay inside and order it from mouser or something.
with your advice i took a look. they wernt able to get a match off of the part number, so if best buy cant help me out i guess ill have to just paw through the relays that they have to try and find one that would be a closer fit. But ill prolly just end up using a standard sized relay soldered to the board with wires.
This one would probably work pretty well and still fit in the case. Its rated at 12v 15a. You could probably google it to find it in a single quantity.
http://mouser.com/Search/ProductDetail.asp...XpcmaBSsQ%3d%3d
the one thats in there is rated for 30amps and it fried, so if i have to replace im want to use one of the ones that i have thats rated for 30/40 amps
1 - 9 of 9 Posts
