1 - 20 of 34 Posts
When I removed the intake silencer on my car, decided to make a video. Hope this helps someone out:
http://www.youtube.com/watch?v=u2D0b1A5whs
What do y'all think?
Keywords: remove intake silencer 2000 2001 2002 2003 gen 4 G4
Bout time someone did that. Saving the link to give to the noobz :)
The factory notch in the factory jack will actually go into the notch in that rail rather than on the skirt.
What was with the trying to open your door???
Oh good to know...I'll redo the video later or something. Thanks!
I was trying to get into the car to get something...I guess with the car jacked up like that you can't open the door cause of the vehicle flexing.
Thanks for the video, But what did you think of the results?
It is certainly louder. There is no MPG difference that I have noticed. It's not obnoxiously loud...but I also have a K&N panel air filter. I like it, but you may not notice a difference personally. But you can at least say you did it for bragging rights :lol2:
can someone tell me how I get the intake silencer out of my gen 4? need help bad.
n0000000000000bbb!!!! ATTACK THE WEAK AND STUPID!!!!! :punchdoc:
Nick I think you gotta force pull the door open. These doors tend to stick a little. My dad's 04 SES has this on the rear driver door.
My doors open AOK when it ain't jacked up :) How's your door alignment? Maybe lube up the rubber seals on the doors?
Rubber gloves?
Come on, Nick... :p
Discussion Starter #12
Rubber gloves?
Come on, Nick... :p
It sure as heck beats cleaning all that crud out of your hands and nails. :lol2:
<div class='quotemain'>
Rubber gloves?
Come on, Nick... :p
Chicks dig a man who can work on a car so why not have proof of it? Plus there is nothing more manly than smelling like various automotive fluids. I know how Ford can save themselves from ruin: Sell Merconv V cologne and hair gel.
Does this really even do anything? How loud does it make the intake? Isn't there a hole left where the silencer used to be?
Discussion Starter #16
If you'll watch the video, you'll see that yes, there is a hole left where the silencer used to be. Look about 2:20 in.
I don't have a decibel meter, but there is a difference with the silencer removed...nothing substantial though. You gain nothing but a louder intake.
A dremel tool will work quite nicely for cutting a nice smooth line instead of tugging so much. It proved fairly easy on my G3.
G3 design is different from the G4, no need to cut :)
I don't know man, i took it off, and i didn't really even hear a difference. I don't know, maybe it doesn't kick in until you get your foot into it. Oh well
honestly, just taking out the silencer is a bit overrated.
where you really notice it is when you do the k&n and then remove the entire intake pipe and then run a hose from the end of the box into the fender, that definetly have the most power you will ever get from a taurus intake.
if you have that setup and then you go to a open WAI you really can notice the negative difference, i have done it.
Nice video, Nick!
:thumb:
QUOTE (s2knott @ Apr 3 2009, 12:21 AM) index.php?act=findpost&pid=714868
if you have that setup and then you go to a open WAI you really can notice the negative difference, i have done it.[/b]
:picard2:
1 - 20 of 34 Posts
