1 - 12 of 12 Posts
Pls help me on this guys: the problem is the smell from the outside is coming through inside the car, how can I fixed this? thank you in advance.
as in like dead skunk type of smells? there really is no way to prevent it unless you turn off your climate control entirely...
oops sorry to confuse you on my post, what I mean is whatever the smell from outside it goes inside, for example if an old bus running in front of you all the exhaust smell will suffocate all the person inside, or if I passed by stinking canal. And I don’t think I have climate control, or should I consider also the switch of the A/C. Is the MAX A/C switch open the vent as well?
AFAIK no matter what setting it is in it still draws air from outside the car. hopefully someone that knows for sure will pipe up.
you could try replacing the cabin air filter with a new one if your car has it (probably wont help much with the hole smell thing but never hurts to have a fresh filter in there) you could spray an air freshener on the filter or in your vents but the smells will most likely just combine
QUOTE (sable23 @ Jun 23 2009, 11:58 AM) index.php?act=findpost&pid=734440
you could try replacing the cabin air filter with a new one if your car has it (probably wont help much with the hole smell thing but never hurts to have a fresh filter in there) you could spray an air freshener on the filter or in your vents but the smells will most likely just combine[/b]
i already replace my cabin air filter, you mean all the tauri and sable have same issue as mine?! is anyone notice this?! i drove mitsubishi gallant before but dont remember experience this.
every car i have ever driven without the re-circulate button has always done this
Replace or check the weather stripping?
Are their gaps in the window or door?
MAX AC recirculates the air in the car and does not use the external vent feed for air.
They sell a carbon vent filter for the Taurus, get one and it will reduce the outside odors.
A thirteen year old car might have some missing weather stripping and that may contribute to the issue.
Discussion Starter #11
QUOTE (2000Sable @ Jun 23 2009, 02:00 PM) index.php?act=findpost&pid=734446
A thirteen year old car might have some missing weather stripping and that may contribute to the issue.[/b]
weather stripping? where can i find this?! i probably check this one up!
1 - 12 of 12 Posts
