I am looking for any suggestions on changing out the VSS on a 99 taurus. Corrosion of the bolt into the trans housing makes me feel like I am going to shear off the head of the bolt:eek:. Any tips to break this loose without breaking the bolt?\\
Thanks
If the bolt shears off, you will need to take it to a trans shop for R&R of the trans, not cheap. Ditto if you snap off the plastic gear at the bottom of the VSS inside the trans. I had one stuck in there very hard (the VSS) and I had a trans shop change it for me for $200. R&R can run $600 or more, be careful!
