1 - 11 of 11 Posts
· Registered
All tools are OBO PLUS shipping, PM me with offers!
Money orders, cash (local only) and paypal is accepted (will calculate pp fees if not wanting to send as gift.
Items are NEW unless otherwise noted. Part numbers are listed so you can pull it up online and see what it is. I can provide pictures for each item as well.
Everything is also advertised locally for sale in Maryland and I reserve the right to give local sale priority.
BRAND / ITEM NAME-DESCRIPTION / PART NUMBER / PRICE
Actron: Vacuum & Pressure Tester Kit #CP7802 $17.00
AmPro: 1-3/16" Oil Pressure Sending Unit Socker #12600 $11.00
AST: Honda Serpentine Belt Wrench #HON1419 $30.00
AST: Drive Line Fluid Filler #ATF1000 $300.00
Astro Pneumatic: ¼” Heavy Duty Riveter #1426 $35.00
Attwood: Universal Gear Lube Pump For 32oz Bottles #11891D7 $10.00
Blue-Point: 11pc Gasket Punch Set #PGH8A $51.00
Blue-Point: Dual Punch Air Tool #AT185 $370.00
Blue-Point: 40pc ¼” Stubby Socket Driver Set #BLPBSS40 $159.00
Blue-Point: 5pc Line Disconnect Tool Set #LDT5 $50.00
Blue-Point: Combustion Leak Tester Kit #GDCT16 $85.00
Blue-Point: 24” Magnetic Pick Up Tool #DPTM24 $27.00
Blue-Point: 24” Flexible Four-Claw Pick Up Tool #DPTC24 $27.00
Blue_point: Feeler Gauge #FB-300A $15.00
Blue-Point: Tail Pipe Expander 2-1/2 to 3-1/4” #TC-56 $50.00
Blue-Point: 3-1/4" Telescoping 29" Mirror #UIM325 $15.00 (USED)
Blue-Point: Compact Infrared Thermometer #RTEMPB120 $55.00
Blue-Point: Universal Import Radiator Drain Plug 3/8 Drive Socket #YA9190 $22.00
Blue-Point: Open End Aluminum AN Fitting Wrench Set #ANWR708A $194.00
Blue-Point: VW/Audi Spark Plug Boot Puller & Installer #YA9818 (TWO) EACH $25.00
Blue-Point: Ratcheting Tap and Die Wrench #TDW1000 $95.00
Bosch Digital Miter Finder 17” Protractor #DWM40L $300.00
Bosch: 7pc BlueGranite Turbo Carbide Hammer Drill Bits Set #HCBG700T $20.00
BrownTool: 16 pc Dimple Die Kit #DDSET-8 $150.00
Cal-Hawk: 5pc Metric Offset Box Ratchet Wrench Set #CCW5R0M $12.00
Cal-Van Tools: 6 pc Speed Wrench Set # 460 $75.00
Cal-Van Tools: 13/16" Spark Plug Speed Stick #889 $25.00
Cal-Van Tools: 5/8" Spark Plug Speed Stick #888 $25.00
Cal-Van Tools: 2 Jaw Pulley Puller Reversible #941 $25.00
Cambell Hausfeld: Sandblasting Kit #AT1226 $20.00
CarQuest: One Liter Pressure Spray Bottle #CPS80002 (TWO) EACH IS $25.00
CarQuest: Seal Driver #STL24800 $35.00
CarQuest: Tank Conversion Kit #S682 (TWO) EACH IS $30.00
CarQuest: Steering Wheel Lock Plate Tool #39638 $12.00
CarQuest: Pickle Fork Kit #801552 $25.00
CarQuest: Ford Oil Cooler Line Disconnect Tool #39625 $10.00
Clarke: Hand Held Abrasive Blaster #SB9004 $25.00
Clarke: Abrasive Spot Blasting Kit #SB9005 $25.00
Craftsman: 10pc 3/8” Crows Foot Metric Set #4363 $50.00
Edlebrock: Chevy Throttle Bracket #8036 $25.00
ES: Fuse Buddy 20amp ATC Tester #304B $20.00
ES: Fuse Buddy 30amp ATC Tester #306B $25.00
EZ Red: 7 Pin Connector Cleaning Brush #EZBK517 (THREE) EACH IS $10.00
GearWrench: 25-pc XL Pass-Thru ½” Drive Ratchet Set #891226 $120.00
GRIP On Tools: 8 or 9 piece Deep Impact Socket 3/4 “ Drive SAE #73590 $60.00
GRIP On Tools: 9pc SAE ¾” Shallow Impact Socket Set #73586 $45.00
GRIP On Tools: 18pc Tamper-Proof Torx/Star Screwdrivers & Allen Wrenches Set #????? $100.00
GRIP On Tools: 13pc ½” Drive Crowsfoot SAE Set #90145 $45.00
IPA: Grease Joint Rejuvenator #7862 (TWO) EACH IS $40.00
JobSmart: Siphon Feed Abrasive Blaster #3907837 $20.00
K-D Tools: 8pc Master Sensor Socket Kit #41720 $40.00
K-D Tools: Universal Compression Tester Kit #3305 $35.00
K-D Tools: 3/8” Drive 25-250 in./lbs. Micrometer Torque Wrench #3459 $140.00
K-D Tools: Steering Wheel & Crankshaft Pulley Puller #2291 $15.00
K-D Tools: Master Cooling System Tester #3700 $150.00
K-D Tools: Ford 7.3L Fuel Filter Tool #3526 $15.00
K-D Tools: Oil Pressure Sender Unit Socket #3272 $10.00
K-D Tools: Double Flaring Tool #2199 $70.00
K-D Tools: 3pc Oil Filter & Canister Socket Set #41830 $35.00
K-D Tools: 2 Ton/2 Jaw Reversible Gear Puller #18.00
K-D Tools: GM Clutch Plate Remover & Installer #2416 $30.00
K-D Tools: Oil-Seal Remover & Installer #492 $25.00
Klann Tools: Fuel Line Pliers #KL-0121-38 $95.00
Klein Tools: Angle Climbers Pads (Left & Right) #52094 $71.00
Legacy: 8pc Automotive Lube Accessory Kit #L2551 $115.00
Lisle: 9pc Bearing Race and Seal Drivers #12980 $60.00
Lisle: 24" Magnetic Tool Holder #21400 $20.00
Lisle: Brake Bleeding Kit #19200 $10.00
Lisle: Engine Tilter #22550 $40.00
Lisle: Inner Tie Rod Tool #45750 $53.00
Lisle: Tie Rod Separator #18520 $15.00
Lisle: 10pc Cap Filter Wrench Set #54920 $50.00
Lisle: 26pc Stud Remover & Installer Set #71000 $155.00
Lisle: Small Hose Clamp Vise #44500 (TWO) EACH IS $15.00
Lisle: Truck Wheel Stud Installer #28950 $20.00
Lisle: Angled Disconnect Tool Set #39400 $10.00
Lisle: Spark Plug Tube Remover #51870 $18.00
Lisle: Bearing Race & Seal Driver #12600 $29.00
Lisle: "On The Car" Valve Spring Compressor #16750 $26.00
Lisle: Metric Clutch Alignment Tool #61750 $20.00
LTI Tools: Timing Gear Pliers # LT-995 $75.00
LTI Tools: 8 Piece Wheel Torque Master Kit #LT-1500 $150.00
Makita: ¼” Die Grinder #GE0600 $110.00 (USED)
Mac Tools: 9-PC. 3/8” Drive SAE Box End Torque Adapter Set #SXB92H $170.00
Mac Tools: Gland Nut Wrench #GNW63 $120.00
Mac Tools: Lock Pin Remover #LPR7122R $155.00
Mac Tools: Master Harmonic Balancer Installer #TP1330 $105.00
Master Mechanic: 115pc Drill/Screw Set With Soft Roll Up Case # 112695 (TWO) EACH IS $26.00
Matco Tools: Manual Brake Bleeder Kit #1MANBB58 $67.00
Matco Tools: Digital Tire Inflator Gauge #DT4 $125.00
Matco Tools: A/T and Engine Oil Pressure Tester #ATG5AK $200.00
Matco Tools: 3pc Spark Plug Socket Set #SP6897 $87.00
Matco Tools: 4 pc Race Bearing Punch Set #SPBR4K $128.00 Missing 7/16” x6” piece $70.00
Matco Tools: Pitman Puller Set #PA3010 $227.00
Matco Tools: Ford 6.0 Powerstroke Oil Line Disconnect Tool #MST6594 $30.00
Matco Tools: 6pc Pin Punch Set SAE #SPP6KA $105.00
Matco Tools: 6pc Pin Punch Set Metric #SPP6MP $125.00
Matco Tools: Compression Tester Adapter For 1st Gen Ford 3v #CT611 $45.00
Matco Tools: 3/16" Tubing Bender Pliers #TB441 $38.00
Matco Tools: Adjustable Tap Socket Set #ATS2 $54.00
Matco Tools: Harmonic Balancer Puller & Installer Kit #MST4531 $100.00
Milwaukee: Cordless 2.4v Screwdriver #6546-6 $120.00
MSD: TFi Hi-Performance Replacement Coil #8227 $50.00
Napa: Power Steering Pump Pulley Service Kit #41560 $38.00
Napa: Rear Axle Bearing Puller Set #41710 $36.00
Napa: Bubble Flaring Took Kit #3482 $25.00
Napa: A/C Leak Finder Kit #801552 $50.00
Napa: 9” Self Leveling Locking Pliers w/Clamp $20.00
Napa: Harmonic Balancer Installer Kit #3679 $85.00
Napa: Bearing Packer #715-1256 $25.00
OEM: Pulley Puller Installer Kit #27031 $35.00
OEM: Pulley Puller Installer Kit #25298 (TWO) EACH IS $35.00
Old Forge Tools: Double Flaring Tools Kit #7203 $35.00
OTC: Close Quarters Pitman Arm Puller For Truck/SUV #6496 $60.00
OTC: GM TBI Fuel Pressure Adapter #7665 $55.00
OTC: Bearing Splitter Combo Pack #1183 $350.00
OTC: Ball Joint/Tie Rod End Remover #7315A $50.00
OTC: Ball Joint, U-Joint & Brake Anchor Pin Service Kit #7249 $115.00
Performance Tool: 419pc Metric 32 Size O-Ring Assortment #W5203 $15.00
Performance Tools: Ford Power Steering Pump Pulley Installer #W87021 (TWO) EACH $25.00
PitPRO: 4 pc 16” Long Reach Needle Nose Plier Set $45.00 (USED)
Ray Tools: Ratcheting Cable Cutter #RT2005 $350.00
Rigid: Seesnake Micro Inspection Camera #25643 $510 (comes with accessory kit and 5 36" extension cables)
S&G Tool Aid: 5pc Ratcheting Terminal Crimping Kit #18920 $72.00
SK Hand Tools: ¼” Drive Metric Deep Impact Socket Set #31036 $210.00
Scotch-Brite: Brake Hub Cleaning Disc Kit #07547 $25.00
Snap-On: Quick Cutter Hand Saw #HS50 $60.00
Snap-On: Twin Tube Fluorescent Drop Light #ECU4007 (TWO) EACH IS $52.00
Snap-On: Torque Adaptor, 5/16", 12-Point, 3/8" drive #FRDH101 $30.00
Snap-On: 48pc SAE & Metric Master Rethreading Kit #RTD48 $125.00
Snap-On: 7pc Pin Punch Set w/case #PPCD70BK $134.00
Snap-On: Miniature Butane Blow Torch #TORCH6 $75.00
Snap-On: Heavy Duty Narrow Blade Striking Scraper Set #PKN301 $105.00
Snap-On: Tapered Repairmans Reamer 1/8-1/2” #R120 $27.00
Snap-On: Tapered Repairmans Reamer ½-1” #R121 $67.00
Snap-On: Remote Start Switch #MT302A $70.00
Snap-On: ¼” Drive Extension Connector #TZ1 $20.00
Snap-On: Steering & Alternator Pulley Puller and Installer Set #CJ3PSA $300.00
Snap-On: 9-Piece Fine Tooth Serpentine Belt Wrench Set #YA9350B $145.00
Snap-On: 1/4" Tubing Bender #TBS100 $25.00
STANT: 30 lb. Cooling System And Pressure Cap Tester #12270 $70.00
Sunex: 6pc Metric Jumbo CrowsFoot Wrench Set #12-01972 $92.00
Sunex: 8pc Metric Jumbo CrowsFoot Wrench Set #12-01973 $57.00
VIM Tools: 10pc 3/8” Drive 5-Point Security Driver Set #V5PSD $40.00
Zurn Pex: QickClamp Large Crimping Tool #QCRTQCL $40.00
· Registered
Discussion Starter · #2 ·
Second part of my list:
Alltrade: 6pc Wood Chisel Set #835758T $27.00
AmPro: Ford/GM Quick Disconnect Tool #T70048 $10.00
Blue-Point: Carbide Cutter Kit #YA333A $140.00
Blue-Point: AN Fitting Adjustable Wrench #ANADJ8 $76.00
Blue-Point: Set of Four Micro-Grip Clamps #MG2000 $95.00
Blue-Point: 6 Round Pin Trailer Tester #TLT6 $20.00
Blue-Point: 3pc Turbo Speed T-Handle Set #TURBOT103 $177.00
Blue-Point: Fuse Buddy™ Pro Test Kit #EEFB310 $99.00
Blue-Point: Deluxe Hubcap & Wheel Lock Removal Kit #YA1005C $55.00
Blue-Point: Metric Valve Keeper Remover/Installer #GA317 $45.00
Cal-Hawk: 6" SafetyTwist Wire Twisting Pliers #CPLWT6 $12.00
Gorilla Tool Company: Metric Bolt Sizer/Thread Stainless Steel Screw Pitch Gage Tool #M98 $57.00
Gorilla Tool Company: SAE Bolt Sizer/Thread Stainless Steel Screw Pitch Gage Tool #A98 $57.00
Hoffman: Power Steering Rack/Pinion Tester #HOFTU22APB $100.00
IPA: Disc Brake Pad Pressure Tester #007884 $155.00
K-D Tools: Ford Ball Joint Cam Tool #3316 $15.00
K-D Tools: Combination Heavy Duty Snap Ring Pliers #2012 $43.00
K-D Tools: Pitman Arm Puller #KDS2289 $19.00
K-D Tools: Stud Extractor #1708 $33.00
K-D Tools: Remote Control Starter Switch #124 $15.00
K-D Tools: Valve Grinder (5/8", 13/16" Diameter) #501 $5.00
K-D Tools: Valve Grinder (1-1/8", 1-3/8" Diameter) #505 $6.00
K-D Tools: Oetiker Clamp Pliers #3374 $20.00
Lisle: GM Heater Hose Coupler Remover #62260 $10.00
Lisle: Ratcheting Lock Nut Tool #28000 $39.00
Mac Tools: Door Hinge Pin Popper #DHPP-21835 $35.00
Mac Tools: Gear and Pulley Puller #pp515A $50.00
Mac Tools: Electric Marking Pencil #EP9NS $45.00
Mac Tools: Bench Brake Bleeder #BBB32900 $45.00
Matco Tools: 1/2" Torque Angle Gauge #MST65 $17.00
Matco Tools: Metal Brake Feeler Gauge Measure Pad Thickness Tool Set #BG842 $15.00
Matco Tools: Lock-on & Hold Hex Nut Driver Set #SLND2 $61.00
Matco Tools: Universal 7/16" to 3/4" Nut Cracker #MST4576 $46.00
Matco Tools: 3/8" Drive Stubby 88 Tooth Ratchet #BR4T $82.00
Matco Tools: "Ball" Torx Set #BT341 $70.00
Matco Tools: Pedal Press #PP29 $52.00
METCO: 10pc Left Hand Drill & Screw Ext Set #LHEZ10 $70.00
Milwaukee: Variable Temp Heat Gun, 200° F to 1050° F #8978-20 $158.00
Napa: 115° Right Angle Pencil Die Grinder #6-1016 $119.00
OTC: Universal Inner CV Joint Puller #7507 $30.00
OTC: Injection Spring Lock Coupling Adapter #7236 $37.00
OTC: Ford Valve Spring Compressor Tool #7928 $93.00
OTC: Cable-Type Flexible Hose Clamp Pliers #4525 $35.00
PitPRO: Suction Gun #PT520 $20.00
PitPRO: Full Size Righe Angle Die Grinder #PT2432 $43.00
Plews: Hand Transfer Pump #30-108 $25.00
RC-One: 6pc Hex Driver Tool Set (0.05", 1.5mm, 1/6", 5/64", 3/32", 2.5mm) $40.00
Snap-On: Transfer Punch Set #DPFT528A $65.00
Snap-On: 3/8" Torque Angle Gauge #TA358 $90.00
Snap-On: Nut Splitter #NC52 $97.00
Snap-On: Carbide Burr Long Reach 4pc Set: #VWBL400 $219.00
Snap-On: Extractor Tapered Bit 4pc Set: SR40K $77.00
Snap-On: 9pc L-Shape Metric Stubby Ball Hex Wrench Set #AWMBS9 $38.00
Snap-On: 13pc L-Shape Ball Hex Stubby Wrench Set #AWBS13 $34.00
Snap-On: 5pc Non-Marring Scraper Set #PKN500 $47.00
Snap-On: 45° Angled Serrated Needle Nose Pliers #EP892A $53.00
Snap-On: 45° Angled Retaining Ring Pliers #SRPC7045 $20.00 (USED)
Snap-On: Power Steering/Alternator Pulley (Chrysler, Ford, & GM) #CJ124A $99.00
Snap-On: 8" Mobea Hose Clamp Pliers #HC48CP $38.00
Snap-On: Brake Adjuster for Chevy Truck w/overload springs #S9523 $26.00
Snap-On: 8pc Solid Carbide Burr Set #VWB800C $200.00
Snap-On: 12 Volt Ratcheting Lamphead Utility Light #ECU412BK $100.00
Snap-On: 12 Step Blade Feeler Gauge #FB308D $38.00
Snap-On: 10° Offset 12-point Midge Box Wrench Set #XID604KA $107.00
Sunex: 3/8" & 1/2" Drive Adapter & Universal Joint Impact Set #3305 $46.00
· Registered
bump ttt
· Registered
Why are you selling them?
Cleaning out my garage/work shop, most of the tools are spares I had when I ran a small repair business out of my own garage.
· Registered
bump ttt
· Registered
bump ttt
· Exalted Grand Poobah
Try selling on Craigslist, maybe some pro shops will be interested. Every one of those tools are available locally to us amateurs at Harbor Freight or Northern for less than you ask, and no shipping. For us amateurs, tools of this quality are overkill. Hope this helps you some.
· Registered
Discussion Starter · #9 ·
Have tried Craigslist, and sold some stuff but dealt with too many scammers. Can't hurt to list and try on the forums. I list everything OBO, if someone wants to offer a price shipped I have no problem with that, I'll entertain all offers at this point cause I've had the stuff for so long.
· Registered
Discussion Starter · #10 ·
bump ttt
· Registered
Discussion Starter · #11 ·
Everything has been sent to auction, can close the thread.
1 - 11 of 11 Posts
