1 - 11 of 11 Posts
I have searched and searched where can i get one for a tec and what are the general prices and installation
Originally posted by SableSal@Jun 16 2004, 01:22 AM
VAK? What's a VAK? Sorry for my dumb question... but just curious if someone would explain this to me
SABLESAL
Same here...The bunny says it all.
Originally posted by mikehawk@Jun 16 2004, 09:53 AM
It cuts out the alternator and cooling fans, and partially cuts the power steering when you go WOT. Similar to a UDP, but electronic.
:withstupid: What Mike said. VAK stands for Vacum Accessory Kill. I'm getting ready to purchase one from Paul (SHOZ123) soon. When i spoke with him last he said he was selling them for 100 delivered. I'd check with him to make sure this is still the case though.
Best $100 performance mod you can do, IMO. The difference is noticable, at least on my car. From my experiences, anything less than 5HP (like a CAI) is unnoticable on the butt dyno. >5HP for $100 is pretty good, IMO. And the install is pretty easy once you find the right vacuum tube (inside joke between me and SHOZ123 :) ) Seriously, it only takes 20 minutes or so.
In addition to the stuff mikehawk said, it also cuts off the A/C compressor if it is on (A/C, EATC cold, or defrost.) Our cars already cut the A/C compressor when you go WOT, but not instantaneously like the VAK does.
Plus, when you explain the VAK to other car modders, they'll think you're 733t. :)
Yes I sell and make the VAK. I cannot stress enough what a really good battery will do with the VAK compared to just a normal auto-start battery.
I have a small Odyssey PC 925 that only weighs 26 lbs but still puts out the power when needed. A PC 1200 is recommended but if you have a large electrical load there is a PC 1700. http://www.odysseyfactory.com/specs.htm
I do have a 100A voltage regulator. When my VAK kicks in so does the voltage regulator which I have set at 15.15V. The alternator kicks out and the lights get brighter on mine. :flamethrower:
so is that a pic of the VAK or the voltage regulator?
Correct me if I'm wrong, Paul...
That picture is in the trunk. It shows the voltage regulator (it says "Jacobs AccuVolt") and apparently a solenoid(?) in the foreground.
The VAK sits in the engine bay. It is a small black box, about 3"x4"x1.25", with a loom of wires and a 1/4" vacuum tube coming out of the housing.
Yes that is the voltage regulator. The VAK really isn't much to look at.
Here is a VAK installed on my car. They look a bit different now.
1 - 11 of 11 Posts
