Re: 1995 Taurus 3.8L Engine. Anybody know what the vacuum reading should be off of the port on the upper intake manifold.
Idle vacuum with warmed up engine and no loads on engine (AC off, minimal electrical loads, etc) should be 18 to 20 inches Hg. At high altitudes, vac will be a little lower
Thank You Jeff. So, if my vacuum reading is at 14-15, I have to assume that I have a vacuum leak. When I rev up, it doesn't go any higher that 16.
Unless you have a long duration / small LSA cam in it, 14 is too low unless you are up at 6000 feet altititude. A good rev should drop vac to near zero, and when you let off the throttle, vac should go to 20+ inches as RPM drops to idle.
