Anyone have a part number or description of the following: A 90 degree vacuum elbow, not the main vacuum line but a secondary one just behind the main one further from the TB. Hooks to about a 3/8in nipple on the intake and splits down into 2, 1/8in holes that red solid vacuum lines, one of which goes to the FPR.
Basically, 98 'tec engine backfires, spits this vac elbow off and now it won't stay on. Had to stick it on with a worm clamp to get home, but the engine runs just fine. Is the elbow just aged and expanded or is something else supposed to be on there? I sprayed all over back there with MAF cleaner and no change in idle.
Backfiring is not normal and is usually a timing/ignition issue.
Oh, I'll throw in the fact that seafoam was at play here....
:unsure: :pat: :( *puts on flame suit* :flamethrower:
Ok, So does anyone have a diagram for a 96-99 Duratec Intake/Vac system with part numbers? Otherwise it's going to be a fun day at the stealership getting this part.
The dealer would have exploded pics of the intake with all the parts. Pretty easy if you know what you are looking for.
For anyone else that may need to look..
$147.95 for the part. You have to buy the whole vacuum assembly for the EGR/FPR system. They don't just sell the only part that's going to rot out..... The hose clamp is working just fine with no leaks, and a trip to the pick n pull is in the near future.
