1 - 10 of 10 Posts
I went back to the pull-a-part yard and found a Sable AND Taurus where both had instrument gauges that has a silver trim around them. I want to know if there is a way I can change the miles on the used gauge cluster to match the current mileage on the car?
one cluster has 148K on it and the other has 184K
haven't had time to switch the chips yet, but it works slightly better since i cleaned the metal contacts with some alcohol pads.
maybe if I can roll the mileage back on the 2 used gauges, maybe they will be better (they look better too with the silver trim around the gauges)
Do you have digit wheels on odometer? I have the same setup on my 97 F150 and need to do the same with the JY cluster. Someone did with 2 small screw drivers. With 1 separate the moving mechanism from the wheel, with the other turn the wheel. Let me know if it works.
Wait why are you replacing the speedometer? The whole instrument cluster will dissassemble. Clear plastic, black/silver bezel, then the gauge pods will separate if you want to swap your speedometer over. Otherewise, under Topic Finder you'll find a writeup on adjusting the mileage.
Discussion Starter · #6 · (Edited)
the reason I'm replacing the gauge cluster is I found this beauty cluster (along with another one just like it from a Taurus) in a junk Sable at the pull-a-part yard. I thought it would look great with the matching grey interior. I just want to match the mileage the car has now so I can put the new cluster in
Or, would it be easier just to swap the needles and silver trim from this cluster to my current one?
Also scored a rear spoiler off a '99 Taurus that will fit my Sable (I set it on the Sable and it will sit perfectly, just needs to be repainted from gold to silver)
I put the same cluster in my Taurus GL, I like it better as well...there is a write up somewhere I think in the topic finder about how to change odometer setting. when I replaced the needle to the accurate speed I used my GPS... I had the clear plastic cover off also and when the GPS said 60 I put the needle back on. I can tell you more if you want about how I did mine.
Discussion Starter · #8 · (Edited)
as far as just swapping the needles from orange to red, is there any special precautions or do i remove them as the needles sit when the cluster is removed?
btw, I'm only swapping needles and the gauge trim.... not replacing anything else.
When I changed my needles to the red ones, I went down the highway and set the cruz to 60 mph then pulled the orange needle off and put the red one on. If I remember right I used a dinner fork to get under and pop the old needles off lol
Discussion Starter · #10 ·
1 - 10 of 10 Posts
