The rear tires on my '99 Sable wear on the inside. It is sort of a chopped or serrated pattern that makes for a noisy ride. What causes this?
Your rear camber is off, get a 4 wheel alinement. Same thing happened to mine, after hitting a large pot hole with that 1 wheel.
If your shock absorbers are worn too, it can aggravate the problem, but it is typically an alignment issue. I would get the alignment checked and corrected.
